Compare two worksheets
Brian Street
Post by Brian Street »
Hello,
I'm trying to find out how, or if, I can compare two or more worksheets and highlight the differences. I have 3 locations of music files and I've put a list in separate worksheets in the same workbook, and now I want to find out which files are different between them.
I tried searching the documentation but came up empty; perhaps I'm not using the correct search term.
Thank you for your help,
Brian.
Re: Compare two worksheets
Thanks for your post. There is no such feature available/planned for FreeOffice, but you can do it manually by using vlookup formula in both the sheets, and you will know the differences.
