User defined functions
GuernseyMan
Post by GuernseyMan »
I've played with the demo version of BasicMaker quite a bit and I do enjoy using it.
Using VBA I tend to create my own functions which can be used within Excel. A simple example is "COLUMNWIDTH" which returns the width of a range in whatever measurements Excel uses. The cell would have "=COLUMNWIDTH(B:G)".
I can't see a way of getting the same functionality in Basicmaker/Planmaker. I can see that Basicmaker can control Planmaker very well but can't see how to call a Basicmaker routine from inside Planmaker. Am I missing something?
Re: User defined functions
Thanks for your post and for trying BasicMaker, but this feature is currently not available. I have forwarded this as an improvement suggestion to our product management.
