No Tabs Visible in FreeOffice "Presentations"
sutapa_saha_1234
Post by sutapa_saha_1234 »
1. No Tabbed Interface is visible in “FreeOffice Presentations 2021” .
2. There are 32 PPTX Presentation Files to be opened . Tried in both Ribbon Interface and Simple Menu-Based Interface .
3. Only from the “Window” Menu / “Window” Ribbon Tab it is visible that there are “32 Presentations” and it is possible to switch only from there , instead of tabs .
Is there something in settings to activate tabs ? (Using “FreeOffice Presentations 2021”(For Personal Use) .)
Thanks in Advance . :D
Re: No Tabs Visible in FreeOffice "Presentations"
Thanks for your post. Tabbed interface is actually a premium feature available in commercial version only and not in FreeOffice.
For more detailed comparison, please refer to our website: Discover SoftMaker Office
sutapa_saha_1234
Thanks !!!
Return to “FreeOffice Presentations 2021 for Windows”
