Advanced comparison
Advanced comparison
The advanced comparison feature is very poor, useless for me. It needs to be seriously improved.
Re: Advanced comparison
Thanks for your post, but please share complete details of the problem, steps involved with sample file for better understanding of the problem.
I am referring to the way differences between files are presented. Just compare with the way Acrobat shows them.
Yes, please share the details where you are getting problem in comparing the files so that we can check it.
I am sending you the comparison results in Acrobat (an old version) and FlexiPDF (differences highlighted) of two brief PDF files. The difference is obvious.
- Acrobat_XI_comparison.pdf
- (74.57 KiB) Downloaded 4561 times
Thanks for sharing these sample files. I have forwarded the details to our developer team.
