PDF printer does not ask about name and directory for saving
Oslaf
Post by Oslaf »
Hi, I'm wondering why the PDF printer does not ask about name and directory for saving as the other similar printers. The destination folder seems to be C:\ProgramData\temp, which is not easy to reach and saved files have very meaningless names.
Am I doing something wrong or this is an absent but necessary feature in this program. Please your help. Thanks in advance.
Oslaf
Re: PDF printer does not ask about name and directory for saving
Thanks for posting your problem. Whenever you print using FlexiPDF virtual printer, it opens the printed PDF file for you. Please click on Save or press Ctrl+S and save this file to your desired location with filename.
The file name with timestamp in C:\ProgramData\temp folder is only for temporary use.
Return to “FlexiPDF 2022”
