Tab bar - opened document tab bar
kampion998
Post by kampion998 »
under my toolbars is an open documents tab bar.
can this be hidden?
on my tiny windows 8 netbook, i need all the room for the actual document i am working on. the tabs are not needed as i am only working on the one document, i also hope this is not in the android version, since it would pretty much mean i would not see more than one line of the document.
Re: Tab bar - opened document tab bar
Thanks for your post. Currently, this option is not available, but I have forwarded this as an improvement suggestion to our product management.
I have moved your post to the appropriate forum.
Oh, yes. PLEASE make that tab bar optional!
I know some people like to keep a bazillion documents open simultaneously, and they use the tabs to navigate among them. Personally, I HATE tabs, and I turn them off whenever and wherever possible in everything except my browser. I use Thunderbird as my e-mail client, and that also defaults to showing a tab bar. It's not easy, but it can be disabled in Thunderbird, and I have done so.
When TextMaker allows disabling the tab bar, I will disable it in a heartbeat. Please make this a top priority. It should be just another option in the pop-up (or drop-down, if you prefer) menu box that opens when you right click on any of the toolbars.
Reminder to SoftMaker: This has been a request for some time. https://forum.softmaker.com/viewtopic.php?f=298&t=22469
