Cannot Print using Softnaker
raunhar
Post by raunhar »
When I try to print any file created in Softmaker (Text or Plan Maker), it does not print. If I try printing using Libre Office, there are no issue.
The printer gets detected in Softmaker but on giving the command, the message "Printing Cancelled" shows up.
Re: Cannot Print using Softnaker
Thanks for reporting this problem. Please check if you are using the latest revision of SoftMaker Office, if not, please update your SoftMaker Office.
Please share a screenshot of the error and also check if you are trying to print on the same printer which you used for other applications.
