Change the colour when redacting an image
ri2022
Post by ri2022 »
When I try to redact a section of a pdf document it only redacts the section to black and I'm trying to make it white. I changed the 'redact style' to another colour but it has no affect when I redact an image.
I can do this operation in flexipdf pro 2017, but flexipdf pro 2022 doesn't work for me.
Can anyone help me?
Re: Change the colour when redacting an image
To change the background color of the redact area, please select the area, click on ribbon format and then change "Fill color" to white as shown in this screen recording.
ri2022
Post by ri2022 »
Thanks SuperTech. That worked well. It would be useful to enter those words you provided into the online manual so it can easily be found for others when they try to search for this issue.
The online manual says "You can use the dialog box Redact Style to change the appearance of the redaction...... etc" when searching "redact image color fill", which is incorrect for this problem.
Thanks.
Thanks for the suggestion. I have forwarded the details to our product management.
Our team have updated the user manuals.
Return to “FlexiPDF 2022”
