Table header when copy/pasting
Klaas Vaak
Post by Klaas Vaak »
When I copy a table from Planmaker and paste it into a markdown file, I get this
https://i.imgur.com/0vpHlMT.png
As you can see, the header Time has asterisks and a slash before and after it, even though in the original spreadsheet this is not the case. It is the same for all the headers.
This happened after the latest service pack.
Re: Table header when copy/pasting
Thanks for posting your problem. Please share the sample files (PlanMaker and markdown file) in which you are getting this problem, and please let us know the name of the software you are using for your markdown file.
If your file is private, please send it to forum[at]softmaker.de with link of this post.
Klaas Vaak
@Supertech: thanks for your reply. Your forum does not allow attaching a file, so I have sent it (Test.xlsx) to forum[at]softmaker.de.
The problem happens when I paste the table into a Typora markdown file.
Note: I am using MacOS.
Thanks for sharing sample file. I have forwarded the details to our developer team for further investigation.
Our developer team checked it and found that this problem is related to Typora software and not related (caused by) to PlanMaker.
Return to “FreeOffice PlanMaker 2021 for Mac”
