External reference
eercons@gmail.com
External reference
Post by eercons@gmail.com »
Hi,
The manual explains in detail how to set up an external reference, but there is nothing about finding where this reference starts from. SO you can see whioch external file it want to acess, but you can't find the individual sheet and cell in a spreadsheet file (With about 60 individual pages in it) where this reference starts from. There is also a lot about updating and changing the reference but nothing about how to delete it. I want to get rid of that reference.
Thanks.
Re: External reference
External cell references: In calculations, you can use cell references that refer to cells located in a different PlanMaker or Excel document. Such references are called external cell references.
You can learn more about it in our user manual: External cell references. It explains everything including how to read and locate sheet name, cell reference etc. You can delete that external reference from that local cell using Del button without any problem.
