Page numbering in x of y format
seena
Post by seena »
I want page numbering in x of y format
How to do it
seena
Re: Page numbering in x of y format
I can explain how to do it with the classic menu. The ribbon menu is probably similar.
Assume you want it in a footer, so the first step is to insert a footer. From the menu:
> Insert
> Footer
You are now in the footer area. To insert page numbers:
> Type "Page" and a space
> Insert > Field > Page Number
> Type a space, then "of," then another space
> Insert > Field > Page Count
Done
Also, see page 111 of the User manual
seena
Post by seena »
I will look into it
seena
