Presentation slide slow won't lauch
Natalie
Post by Natalie »
Hi -- I have had the 2018 version since then.
I recently worked on a Presentation -- and when I tried to view it as a "show" it wouldn't launch
I downloaded the 2021 version and the SAME thing happened.
Please advise urgently as I need this for Church presentation. tx
Re: Presentation slide slow won't lauch
Thanks for reporting this problem. Please let us know if you are facing this problem with any specific file or with every file. If this is with a specific file, please share the problematic file so that we can check it at our end.
You can send your private file to forum[at]softmaker.de with link of this post.
Return to “Presentations 2021 for Windows”
