Custom Merge Fields
lawrencetraub
Custom Merge Fields
Post by lawrencetraub »
I need to add custom merge fields to my documents. I'm not looking to do a mail merge from a database or spreadsheet.
For example:
The document will be run in OneSite (property management software) where the fields are defined. I need the fields to be filled in with the custom information that the user has entered in OneSite. I can do this easily in Word by using the Insert Quick Parts, Field, MergeField option. However, I don't see that option for TextMaker.
Does anyone know how I would go about doing this?
Thanks.
Re: Custom Merge Fields
Post by Jossi »
Sorry, but I can't quite follow you. Am I right when I suppose that you have data stored in OneSite fields and want to import them into TextMaker fields?
anothersite
Post by anothersite »
Did you ever figure out a solution for creating the mergefield?
Thanks for your post. We already have this feature in TextMaker, please share complete details of your requirements so that we can guide you better.
