Won't open
Post here those questions, bug reports and suggestions for SoftMaker Office 2021 for Mac that do not fit in any of the application-specific subforums.
lawrencetraub
Won't open
Post by lawrencetraub »
I've been using all of the office applications from SoftMaker with no issues on my Mac.
When I went to open a document nothing happened. The same when I try to open the application directly. I've logged out and back in and the result was the same.
I'm running macOS Monterey (Version 12.3.1) on a MacBook Pro (2019). The processor is a 2.6GHz Intel Core i7.
I'm not sure what else I need to do to get this resolved.
Any help will be appreciated.
Thanks.
Re: Won't open
Post by Jossi »
Does this only happen with SoftMaker Office or with other apps, too? If it is only a problem with SoftMaker Office, i recommend deleting the program folder and installing it again.
Return to “SoftMaker Office 2021 for Mac (General)”
