Interactive Forms and Tabbing
SeaSteve
Post by SeaSteve »
I'm creating a form with MANY form fields. After creating the first field "Text Box" I copied and pasted it several times in a column and renamed each Field01, Field02, Field03, etc. Then I save and try the file in Reader for testing.
When I try to "tab" to the next form field it jumps around in a different order than I created or named. What's the trick here to set the order?
Re: Interactive Forms and Tabbing
Our developer team have fixed this problem in the latest revision of FlexiPDF. Please update your FlexiPDF and now onwards you will not get this problem in new files.
But for existing files, currently, there is no mechanism to change the field order for which I have forwarded the feature request to our product management.
Return to “FlexiPDF 2022”
