CSV importation doesn't use Normal.pmvx
Kroc
Post by Kroc »
Hi,
I set some preferences for default spreadsheet in ~/Documents/SoftMaker/PlanMaker 2021 templates/Français/Normal.pmvx (default font set to Arial in cells and characters styles, vertical alignment set to middle, and some other things).
It works well for new documents, but when I open (import) CSV files, it doesn't use my preferences but it seems PlanMaker falls back to its own default preferences.
However, CSV files didn't include any formatting information, so why doesn't PlanMaker use my own preferences?
Re: CSV importation doesn't use Normal.pmvx
Default template is actually designed for new files only and not implemented when we open/import CSV files. But I have forwarded the details to our developer team to check what the best possible in this case.
Return to “PlanMaker 2021 for Mac”
