Lag when copyng outsided Planmaker
katk
Post by katk »
I have very annoing problem - when i copy text outside from PlanMaker then after cmd+v it takes about 1-2sec when info arrives to cell and i can continue editing. If i copy one cell to another, then there are no lag, also no lag with PlanMaker Free fersion.
Re: Lag when copyng outsided Planmaker
Thanks for reporting this problem. Please let us know since when you are getting this problem? Is this with PlanMaker only, or with other applications like TextMaker also?
katk
Post by katk »
It is only with PlanMaker, before i use Planmaker Free (without no problems), but as i want use tabs, then i start using payed version this week.
There are no matter if Planmaker has one or more tabs (documents) opened - if i copy from outside program, there is lag, if i copy from one sheet to another or from one document to another in Planmaker, everyting works perfectly.
Texmaker and Presentation works perfectly - no problems.
Thanks for sharing more details. Please check your private messages inbox.
barryhill
Post by barryhill »
Hi
Just for the record, I've notice a copy and paste lag when I am using any of the softmaker software, just as you describe.
barry
Please update your software to the latest revision and then let us know if the problem persists.
Return to “PlanMaker 2021 for Mac”
