SoftMaker crashes
Aleph
SoftMaker crashes
Post by Aleph »
Greetings to all,
I downloaded the 32-bit version of SoftMaker from the repositories,
https://shop.softmaker.com/repo/apt/po ... fice-2018/
which I installed on Antix Linux, however the program crashes without being able to open initially.
I have tried to get the error information, but debug does not work, it does not produce any output.
Code: Select all
luis@antix1:~
$ textmaker18free -debug
Segmentation fault
luis@antix1:~
Any advice?
Thank you.
Re: SoftMaker crashes
We are sorry to inform you, but we are no longer supporting 32 bit, and AntiX Linux was never officially supported.
We recommend use of a 64-bit Linux, as all CPUs built after 2003 support 64 bit. You can check our supported Linux distributions here.
Aleph
Post by Aleph »
SuperTech wrote: Mon Apr 04, 2022 2:04 pm We are sorry to inform you, but we are no longer supporting 32 bit, and AntiX Linux was never officially supported.
Nice to greet you, SuperTech.
Antix is simply a Debian derivative, so in theory it is supported by you.
About the 32bit version: Just a reminder that many people can't afford to buy new hardware, and I believe that with little effort you could maintain a 32bit version, for example for people with few resources, educational centers with old hardware or charities. That's your decision, you can either throw away the 32bit version or give it some good use.
Regards.
Thanks for your suggestion, and we can understand the situation. But honesty, that's not even near little effort. :(
