Google Drive Access Blocked
razazaidi1
Post by razazaidi1 »
Like the other poster when I try to log in to my Google Account using any of the 3 softmaker apps I get the error message
This app is blocked
This app tried to access sensitive info in your Google account. To keep your account safe, Google blocked this access.
razazaidi1
Re: Why does TextMaker need to access my contacts to work?
Problem still not resolved
razazaidi1
Dear as mentioned earlier when I try to log into my Google drive I get a dialog box saying
(This app is blocked)
For your convenience I am attaching a screenshot of the error message
Hope this will be resolved
Screenshot
Screenshot
Re: Google Drive Access Blocked
Thanks for reporting this problem. I have forwarded the details to our developer team.
razazaidi1
Problem still unresolved
Any input from SoftMaker if anything is being done - Thanks
The latest revision 1037 of TextMaker, PlanMaker and Presentations for Android optionally lets you use Android's system file dialog instead of the internal file dialog. This should allow you to access all cloud storage providers, as long as the corresponding app from the respective cloud provider is installed.
You turn this feature on via the "Appearance" tab in the Options dialog, checkbox "Use system file dialog".
Since this feature is still experimental, we welcome your feedback.
