Google Drive & compatibility with chromebooks
Post here those questions, bug reports and suggestions for SoftMaker Office 2021 for Android that do not fit in any of the application-specific subforums.
yowlingcat
Post by yowlingcat »
I am returning to this software after many years - it would be nice to have something cross-platform.
On my Lenovo Chromebook Duet, it installs but when I try to log in to Google Drive, I get a warning box saying Google has blocked this app.
I then tried to install on my Pixel Slate only to find that the Play Store tells me that Softmaker apps are not available for this device?
Any help would be appreciated - the ability to have a pretty full office suite on a CB is attractive.
Re: Google Drive & compatibility with chromebooks
Thanks for trying SoftMaker Office. But Chromebooks or Chrome OS like in Pixel Slate are not supported, but you can try the instructions mentioned in our this article: How to run SoftMaker Office on a Chromebook
yowlingcat
OIC - so it won't run under Android but will run Linux. That's ok, I'll give it a go, thanks for the pointer,
YC
Return to “SoftMaker Office 2021 for Android (General)”
