Display of flexiprinted pdf poor
tsaint
Post by tsaint »
When I use FlexiPDF to print from a web page to pdf, the text in the flexipdf window looks like a screen capture of text, greatly magnified so
the antialiasing (?) shows up. Ie, it's the opposite of crisp, clear viewing.
This is regardless of the zoom I choose.
If I print the same source using a competition pdf printing software, the resulting view in the pdf software has crisp sharp text.
In both cases, I'm talking before OCR, in case that has anything to do with it.
Any help would be appreciated, as I'd like to buy this software if only this problem could be resolved.
FWIW, windows, i7, plenty of RAM, modest but decent graphics card, high res monitor.
Re: Display of flexiprinted pdf poor
Thanks for posting your problem. While printing using FlexiPDF please click on more settings and check DPI setting. If that's low, please increase it and then check the quality of the resultant PDF file.
Return to “FlexiPDF 2022”
