Google Account Mismatch warning
vikingson
Post by vikingson »
First time I've run into this. I'm getting a warning that my Google account is mismatched after I load my document from Google Drive and begin working on it. I open Drive through Softmaker Android Textmaker and choose my account, load the doc again, and get the same warning even after I have chosen my Google account. This looks like a serious bug I haven't seen before.
Re: Google Account Mismatch warning
Thanks for reporting this problem. Please share the steps involved and a screenshot of the error for better understanding.
vikingson
Post by vikingson »
Screenshot:
https://imgur.com/a/vejrmp7
Same thing different documents and different devices. The files show up when I go to Open, Google Drive, but they won't load. My account at Google says Softmaker Office has permission. So I'm at a loss.
Here is the second screenshot:
https://imgur.com/a/cxYF2V0
Once in awhile they will load, but when I try to edit and then save changes the above window pops up.
Thanks for sharing screenshots. Please let us know how many Google accounts you have on your devices ?
vikingson
Post by vikingson »
Just one account. My personal account.
Please clear "all app data" from app info of all three apps, reinstall three apps and check if you are still getting this error.
vikingson
Post by vikingson »
SuperTech wrote: Fri Feb 25, 2022 4:36 pm Please clear "all app data" from app info of all three apps, reinstall three apps and check if you are still getting this error.
Yes, still getting the error. I can open the doc, but when I try to save it I get the same account error screen.
Thanks for trying the step. I have forwarded the details to our developer team for further investigation of this problem.
vikingson
Post by vikingson »
SuperTech wrote: Fri Mar 11, 2022 10:11 pm Thanks for trying the step. I have forwarded the details to our developer team for further investigation of this problem.
Why don't you guys partner with an online storage platform so you won't be at the mercy of changes in code by Google, etc.?
I think OfficeSuite for Android does this.
Thanks for your suggestion.
Our developer team have fixed this problem and the solution will be included in the next update of SoftMaker Office for Android.
vikingson
Post by vikingson »
Thanks!
