How can i show hidden zero values on the left ?
When i write for example 01156050478 on planmaker , i note it hide zero value . What should i do ?
Show hidden zero on left
Hisham Ahmed
- show hidden zero .mp4
- What is the cause for such problem
- (1.3 MiB) Downloaded 5412 times
Re: Show hidden zero on left
The simplest way is to add ' before leading zero, which will allow leading zero.
Hisham Ahmed
I want to apply it for all cells in one button
In that case, please change the Number format of that range to Text, and then you will be able to add zero before numbers.
You can do this by selecting the range > touch and hold > Press Cell > Select Text in number format tab.
Hisham Ahmed
Can you explain this by screen recording , please?
