Language tools
Hisham Ahmed
Language tools
Post by Hisham Ahmed »
When i write in Arabic language the writing doesn't appear .i
am using softmaker presentation 2021 for Android .What is the cause ?
the arabic language doesn't appear.mp4
The arabic language doesn't appear
(1.32 MiB) Downloaded 5772 times
Re: Language tools
Thanks for reporting this problem with screen recording. Please follow these steps :
1. Open TextMaker.
2. Click on ribbon command File | Options | General tab | Check "Extended support for Arabic text" | Apply by clicking on top right checkmark.
3. Please select the appropriate font which supports Arabic language. If there is none, then please download and install one. After selecting Arabic supported font, you will be able to type.
Hisham Ahmed
Re: Language tools
What is the problem ?
What should I do?
Is this option available in softmaker presentation for android?
I choosed times new Roman font. Is good for Arabic language.
المشكلة.mp4
(2 MiB) Downloaded 5844 times
Re: Language tools
SuperTech wrote: Thu Feb 10, 2022 10:02 pm 3. Please select the appropriate font which supports Arabic language. If there is none, then please download and install one. After selecting Arabic supported font, you will be able to type.
Thanks for trying the step, but this third step is also important. If you already have any Arabic font in your device, select it or install one new so that you will be able to type in Arabic.
Hisham Ahmed
Re: Language tools
How can i intstall a new one?
Hisham Ahmed
Re: Language tools
8-) What does this word mean ?
The indicated word in image
Re: Language tools
Hisham Ahmed wrote: Thu Feb 10, 2022 10:35 pm How can i intstall a new one?
To install font in SoftMaker Office for Android, please follow these steps:
1. You can download any Arabic font from your known source or download from internet.
2. Copy that TTF file to /SoftMaker/Fonts/ folder.
3. Click on ribbon command File | Options | Font tab | Make sure your new font is checked there.
4. Click on the check mark in the top right corner to confirm the changes.
Hisham Ahmed wrote: Fri Feb 11, 2022 12:40 pm 8-) What does this word mean ?
As the name says, this button is to import "Hunspell dictionaries" which you can download from our website.
Hisham Ahmed
Re: Language tools
Can you illustrate this by screen recording, please sir?
I have already installed the font with sox from softmaker dictionaries
The form of file font
Hisham Ahmed
Re: Language tools
This error has occurred while installing the font.
Warning while installing the font
Hisham Ahmed
Re: Language tools
The problem has been solven . Thanks alot.
Hisham Ahmed
Re: Language tools
How can i make the bullet on the right?
It is false in arabic language.
The error of the bullet in arabic language
Re: Language tools
Currently, this is not possible in Presentations, but I have forwarded the details to our developer team.
Please create separate/new topics for new problems instead of posting it in the same old topic.
Hisham Ahmed
Re: Language tools
Ok
Re: Language tools
It IS possible to have the bullets on the right in TextMaker. I think you are making the mistake of setting the paragraph alignment to "right-aligned". Instead, you should set the paragraph's writing direction to right-to-left for Arabic.
Hisham Ahmed
Re: Language tools
Can you explain the steps?
Return to “Presentations 2021 for Android”
