Hello,
I get the following message when trying to save files using FreeOffice 2021 Presentations:
"Reading and writing of files may not be possible for illegal copies"
I don't have this problem with either TextMaker or PlanMaker (so far). I registered the program through the usual channel, entered my email and later registered the number I got in the mail.
Thanks.
Illegal copy notice
anselrobot
Illegal copy notice
- freeoffice_2021-error.png (10.53 KiB) Viewed 77534 times
anselrobot
Re: Illegal copy notice
The problem occurs if you do a portable installation (placing "portable.txt" in the installation folder). I reinstalled with a regular install and the problem is gone. I found this answer in the web, a casual comment in a forum. Thanks.
- Contact:
Good that you solved it. I still reported this to the developers because it doesn't sound right.
- Contact:
This will be solved in the nex revision of FreeOffice.
