Markup from a native Word doc not appearing
pipsqueak
Post by pipsqueak »
Hi, I'm new to this software so perhaps I'm missing something basic, but I was sent a marked up contract (changes were tracked) as a native Word document but when I look at it in TextMaker, there is no way to view those changes. Should I see them? Or is this not a supported feature? I am using the latest version of TextMaker.
Thanks.
Re: Markup from a native Word doc not appearing
Post by Jossi »
Please check if in the "Review" ribbon, group “Changes", "Track changes" and "Show" are selected.
pipsqueak
Post by pipsqueak »
Yes, those options are selected but nothing changes in the doc. In other words, there are still no changes shown. I know that the original doc was made in Word 2016 if that helps. Thanks.
Thanks for reporting this problem. Please share the associated file of TextMaker 2021 in which you are getting this issue so that we can do further investigation for resolution.
viewtopic.php?f=382&t=22461
