Generating Random Number In BasicMaker
Mennochio
Post by Mennochio »
Is there a function to generate a random number?
Re: Generating Random Number In BasicMaker
Yes, you can use RND() function to generate a random number from 0 to 1 and then nest it with other functions to get the desired results.
For example, to get random number from 1-30, you can use it like :
Code: Select all
Int(0 + Rnd * 31)
Please check your private message inbox for an important message.
