MS Word Compatibility Issue - Fillable Worksheet
vtpoet
Post by vtpoet »
Attached is a fillable worksheet designed on and for MS Word.
It's possible to fill in the text fields but there's apparently a compatibility bug that prevents one from being able to insert an image.
A workaround is to copy and paste the contents of the document into a new document.
Also: Will test on Softmaker for Windows.
Y1 Travelling waves (fillable worksheet).docx
(19.82 KiB) Downloaded 4503 times
Re: MS Word Compatibility Issue - Fillable Worksheet
Thanks for posting your problem with sample file. I checked this file, it's same in Word also.
vtpoet
Post by vtpoet »
The document works as expected on Onlyoffice and Libreoffice.
vtpoet wrote: Fri Jan 21, 2022 6:07 pm Attached is a fillable worksheet designed on and for MS Word.
But you mentioned that the origin of this document is MS Word. But it's not working in its origin software also, as it's write protected.
Are you able to fill data using LibreOffice?
