Issue when saving an image from Textmaker
ArnaudK
Post by ArnaudK »
Hi !
I saw a glitch, very annoying:
- Use a DOCX document with images in it (PNG format)
- From Textmaker, right-click on one of the image, export it and save image with this name : image_number_13.png
- right-click on one of the image, export it, in the file explorer select : image_number_13.png, then position the cursor after "3", delete it, insert "4" : the cursor goes after the file extension
Strangely it does not happen on images with JPG format.
Re: Issue when saving an image from Textmaker
Thanks for reporting this problem, but we are unable to reproduce this problem. Please share the sample file and screen recording of the problem for better understanding.
ArnaudK
Post by ArnaudK »
Hi !
I managed to reproduce the issue. As this is a confidential document from a friend, how can I send you the document ?
Please e-mail us at the forum[at]softmaker.de
viewtopic.php?f=389&t=22399
