After updating to version 20121.1042-1 using Manjaro Linux, none of the Freeoffice applications start and the error code -105 is given.
At first the program would not start at all, so I changed the name of the SoftMaker config folder in my home directory to get a fresh start, but then "internal error -105" was the result.
Error code -105
- Contact:
Re: Error code -105
Probably wrong access rights to the files in the /etc/SoftMaker folder. Delete the contents of /etc/SoftMaker (but not the folder itself) and try again.
Re: Error code -105
I deleted the files in the /etc/SoftMaker folder, and now the program starts. I am however on 10 days trial, and when I try to activate with my license key, the program just freezes, and I have to force quit it.
- Contact:
Re: Error code -105
Make sure that the folder /etc/SoftMaker has full (777) access rights.
Re: Error code -105
Thanks for quick support. I tried to reboot my system, and now activation works, and the program restarts and is licensed. So all is working well.
