Spell-Checker does not work
ozuser
Post by ozuser »
"Please check with Format > Character the language of your text. If it is
"No language", spell checking will not work."
The box has a language ......... CHECK
"Please click on ribbon command File | Options | Language | Check option
"check spelling as you type" and then select red colour if not already
selected. > Press OK to implement this setting."
I can confirm that this has been implemented ............ CHECK
Hunspell dictionary is listed in the Language window .......CHECK
Yet I still can't get any recognition of spelling errors!
The only other thing I can think of is that I recently downloaded FreeOffice 2021 and deleted FreeOffice 2018.
Re: Spell-Checker does not work
Please share the document in which spell-checker is not working as per your expectation with the screenshot of the problem so that we can analyze it.
ozuser
Post by ozuser »
Sorry for the delay I thought I was going to get email confirmation of any feedback
Thanks for sharing the screenshot.
ozuser wrote: Wed Dec 15, 2021 3:22 am "Please check with Format > Character the language of your text. If it is
Please let us know which language is selected there?
ozuser wrote: Wed Dec 15, 2021 3:22 am Hunspell dictionary is listed in the Language window .......CHECK
Please check and confirm if "English (United Kingdom)" is listed there or not?
ozuser
Post by ozuser »
Dear reader,
We have an answer with the help of SuperTech
I need to download a Hunspell dictionary in the language I require from the SoftMaker FreeOffice website (and remember where you download it on your PC)
https://www.freeoffice.com/en/download/dictionaries
Then go back into your TextMaker doc.
At the top of the page under Tools > Options > Click on Hunspell dictionaries tab > Click on Add Hunspell dictionary
A window opens, locate the Hunspell dictionary you downloaded
Click on it > Click the Open tab and you should now see it uploaded in the TextMaker Dictionaries window
As I am only using this one language, I have also made sure it matches the Language setting in the following -
TextMaker doc. at the top of the page Format > Character > Language
TextMaker doc. at the top of the page Tools > Options > Default language
Thanks for sharing steps. Is it working now?
