Conditional formatting
peterv6
Post by peterv6 »
I'm editing an excel spreadsheet. I created a conditional formatting rule that changed the font color of the cell based on the value of another cell. I can't find a way to see the rule in the sheet. Can someone point me to a resource that explains how to use conditional formatting in playmaker? tia
stascheit
Re: Conditional formatting
Post by stascheit »
In the ribbon user interface, you can see the applied rules for cells by choosing the ribbon command Home | group Format | Conditional formatting >> Manage rules. (in the classic menu interface: Format > Conditional formatting)
Working on Android, you may use the "hamburger" menu (the icon on the far left with the horizontal bars) to choose the classic menu command Format > Conditional formatting.
For more detailed information on conditional formatting rules working with PlanMaker, open the manual via the "Help" entry in the hamburger menu.
The keyword "Conditional formatting" should lead you to the right chapter.
Or use directly this link to the online help: http://help.softmaker.com/planmaker2021 ... tting.html
Return to “PlanMaker 2021 for Android”
