TextMaker/PlanMaker - Print from CMD
glockmane
Post by glockmane »
Hey guys,
is it possible to print via cmd? If yes, how is the syntax?
Best Regards
Re: TextMaker/PlanMaker - Print from CMD
Thanks for posting your query. Yes, it's possible to print the file using command prompt. Following is the syntax:
If you want to print with the default printer:
Code: Select all
TextMaker -p"File name with complete path"
PlanMaker -p"File name with complete path"
Print file with any printer:
Code: Select all
TextMaker -Q"Printer name","File name with complete path"
PlanMaker -Q"Printer name","File name with complete path"
Please don't insert extra space in the command, e.g. there is no space between -p and file name.
