Error with silent installation
Diumen
Post by Diumen »
Hi,
I tried to run the silent installation of FreeOffice 2021 MSI (version 2021.1036) with the parameter
Code: Select all
/qn
However, the installer log shows the following error:
Code: Select all
MSI (s) (9C:B8) [05:35:16:839]: Doing action: ID1360
Action ended 5:35:16: ID1357. Return value 1.
MSI (s) (9C:B8) [05:35:16:839]: PROPERTY CHANGE: Adding TBINST property. Its value is '\tb'.
and the installation fails.
Trying the same with a non-silent installation shows the following in the log:
Code: Select all
MSI (s) (5C:50) [05:49:04:126]: Doing action: ID1360
Action 5:49:04: ID1360.
Action start 5:49:04: ID1360.
MSI (s) (5C:50) [05:49:04:126]: PROPERTY CHANGE: Modifying TBINST property. Its current value is 'C:\Program Files (x86)\SoftMaker FreeOffice 2021\tb\'. Its new value: 'C:\Program Files (x86)\SoftMaker FreeOffice 2021\\tb'.
Action ended 5:49:04: ID1360. Return value 1.
My guess is that there is some custom actions in the
Code: Select all
InstallUISequence
that aren't being run in the
Code: Select all
InstallExecuteSequence
in the MSI which result in the properties not being initialized correctly.
Could you please take a look and let me know if this is an error on my part?
Re: Error with silent installation
Thanks for reporting this problem. Please share the complete command which you used and share a screenshot of that if possible.
Diumen
Post by Diumen »
Thanks for the reply!
The command line I used is
Code: Select all
msiexec.exe /i freeoffice2021.msi /qn /L*v C:\freeoffice2021.log
There is no screenshot I could show because it's a silent installation, but I have attached the full log file.
freeoffice2021.log
(261.56 KiB) Downloaded 3068 times
Thanks for sharing the complete command and the log file. Checking on log, we found that there was error 1603 which is not because of the package.
Please check the complete details here : Error 1603 when you try to install a Windows Installer package: A fatal error occurred during installation
Diumen
Post by Diumen »
Like I said the non-silent installation with default parameters works just fine.
The error I'm referring to occurs earlier in the log i.e., in line 1166
Code: Select all
Fehler 1606. Auf die Netzwerkadresse \tb konnte nicht zugegriffen werden.
the path is set in line 1079
Code: Select all
MSI (s) (E8:F0) [22:23:15:303]: PROPERTY CHANGE: Adding TBINST property. Its value is '\tb'.
I've attached the full log for the non-silent installation with all default parameters for comparison (zipped because it was too large).
Command line to install was
Code: Select all
msiexec.exe /i freeoffice2021.msi /L*v C:\freeoffice2021-non-silent.log
the path is set in line 1184 and 1460
Code: Select all
MSI (c) (D8:7C) [22:29:39:640]: PROPERTY CHANGE: Adding TBINST property. Its value is 'C:\Program Files (x86)\SoftMaker FreeOffice 2021\tb\'.
MSI (s) (50:14) [22:30:06:586]: PROPERTY CHANGE: Adding TBINST property. Its value is 'C:\Program Files (x86)\SoftMaker FreeOffice 2021\tb\'.
freeoffice2021-non-silent.zip
(300.19 KiB) Downloaded 2943 times
Please check the user manual for deployment of SoftMaker Office, same commands are applicable for FreeOffice: User manual.
According to manual, APPLICATIONFOLDER is a mandatory parameter for silent installation.
From next revision onwards, our developer team removed this necessity but till now it is.
