Keyboard shortcuts / hotkeys
springtide
Post by springtide »
I know the shortcut keys to jump to the next word, paragraph, or page of the document. Does anyone know the keyboard shortcut to jump to the next section/chapter (created via Insert/Section Break)?
Re: Keyboard shortcuts / hotkeys
Currently, there is no hotkey to jump to the next chapter, but I have forwarded this request to our product management...
F5, select "Chapter", use Previous and Next buttons.
Alternatively, click on the red dot in the bottom right, select "Chapter" and use the Up and Down buttons.
springtide
Thank you!
springtide
Another hotkey/shortcut question. Is there a key combination to hide/show just the left or just the right sidebar? I can show/hide both sidebars by assigning a shortcut key to "Sidebars" in the Customize User Interface dialog (Ribbon: File/Customize/User Interface). But I never want to see both sidebars simultaneously. I usually want only the left one, for sidebar searches. I can then close the right one with a click, but would prefer not to have to.
(Tip: I assigned Shift-Alt-K to the "Customize" command - the first one in the list, without an icon - so I can get there quickly. I find this is the best place to look up all the commands possible in Softmaker Office. It works in Microsoft Office too.)
You can customize sidebar display by ribbon command View | Group Windows | Sidebars dropdown, there just uncheck all options of right sidebar and then TextMaker will not show you right sidebar in the future.
springtide
A very belated thank you to SuperTech for the sidebar tip.
