Can't change text color on PDF (bug)
mjfox
Post by mjfox »
Hi, I don't know if this is the right place to answer but on my pc I have this issue with Ashampoo pdf pro 3.
If I write a text box the color is always RED. I try to change the color but it keeps RED.
I tried the same operation in the same pc and on the same document using FlexiPDF (evaluation) and everything is fine.
So my question is: is FlexiPdf more updated than the other one? Can I update some libraries in the pc (may be any framework or something else)?
Please help me... :roll:
Re: Can't change text color on PDF (bug)
Turn off tracked changes. But please direct all other Ashampoo questions to Ashampoo.
mjfox
Post by mjfox »
Thank you very much, you made my day.
I attach the solution because I think it can help any Flexi user too.
ps I tried to ask them but they did not understood my problem :D
Return to “FlexiPDF 2022”
