Changing save location
Post here those questions, bug reports and suggestions for SoftMaker Office 2021 for Mac that do not fit in any of the application-specific subforums.
thebrituk
Post by thebrituk »
Does anyone know how to change the save location for files using Text/Plan Maker on a Mac as I usually use cloud based systems to store my documents. I.e iCloud, Dropbox etc
Rob
Re: Changing save location
Do you want to know change of Save location in cloud storage or local storage?
thebrituk
Post by thebrituk »
Cloud storage, hopefully in a folder on iCloud.I should say default save to iCloud as my default location, I know you can as save as...
Once you will save your document to your iCloud location, our application will remember it and will offer you the same next time. This is by default and no setting is required.
Return to “SoftMaker Office 2021 for Mac (General)”
