Shortcuts in Planmaker
bugbear
Post by bugbear »
I'm accustomed working with shortcuts in my old xls program.
Unfortunately, I don't find similar ones in Planmaker. Such as :
- ctrl+C for copying contents of a cell, then an Enter to paste it on another cell
- ctrl+R for duplicating contents of a cell to the neighbouring cell on the right
- ctrl+D for duplicating contents of a cell to the neighbouring cell(s) under
Are some tricks designable with the Softmaker basic language ?
Have you already some ready made in your library ?
Best rgds,
Re: Shortcuts in Planmaker
Use Ctrl+C, then Ctrl+V for copy-pasting cells. That's the Windows standard that Excel violates.
You can customize the keyboard to attach "Fill down" to Ctrl+D and "Fill right" to Ctrl+R. The commands are there, just not bound to these keys.
