Embedded object in document becomes picture on save
karlwan
Post by karlwan »
Hi,
I'm struggling on an issue similar to a previous case mentioned here:
https://forum.softmaker.com/viewtopic.php?f=392&t=21208
I have read the thread, knows that OLE is a MS technology and can't be controlled by Softmaker Office, and I'm not expecting to view or do anything to the embedded object with Softmaker Office.
However, the problem is after I save the document that contains the embedded object with Softmaker Office, and reload it with Microsoft Office or even Softmaker Office itself, the OLE object becomes a picture. I have also checked the size difference between 2 docs, pretty sure the embedded object is totally removed from the doc.
This one is a big issue, cause it's not hard to find a doc with embedded object in business world, Softmaker Office would be unusable for most of the time even if we just want to have some minor update to existing doc with embedded object.
Re: Embedded object in document becomes picture on save
Thanks for reporting this problem. I was able to reproduce it and forwarded the details to our developer team for further testing.
