[Resolved] Can TextMaker automatically convert two hypehns to an em dash?
Eumaios
Post by Eumaios »
Hello,
I've really come to like how Microsoft Word automatically converts two hyphens into an em dash; it's a great convenience. Can TextMaker do that?
Thank you,
Eric
Goghard
Re: Can TextMaker automatically convert two hypehns to an em dash?
Post by Goghard »
Hello Eric,
Do you mean getting the en-dash by writing two dashes and then hitting space? It can be configured as a Smart Text entry. You can find it under the “Insert” tab.
There is also a shortcut for entering en-dashes visible under the “Character” option.
The way I insert it is by using the compose key. Depending on your distro, you’ll have to configure it (https://en.wikipedia.org/wiki/Compose_key).
Hope this helps,
Goghard
Eumaios
Post by Eumaios »
Hello Goghard,
Is this available on the FreeOffice TextMaker version or only on the Office 2021 version?
I ask because I cannot find any Smart Text option under the Insert tab on FreeOffice.
Thank you,
Eric
Re: [Resolved] Can TextMaker automatically convert two hypehns to an em dash?
SmartText is actually a premium feature which is available in commercial versions only.
You can find a complete list of feature comparison here.
Return to “FreeOffice TextMaker 2021 for Linux”
