View sheets in separate windows
eshynartoo
Post by eshynartoo »
Hi,
I've just upgraded to 2021 from the 2018 version of FreeOffice.
Is there a way to view a 2nd, 3rd, 4th sheet etc in separate windows? I need to be able to view multiple sheets side by side from within the same workbook.
Thanks,
eshynartoo
Re: View sheets in separate windows
Currently, this option is not available but I have forwarded this request to our product management...
L Simmons
Post by L Simmons »
Ach! When using the spreadsheet application, there are MANY times when you need to be able to view spreadsheets side-by-side in order to corroborate data. This need doesn't occur so often with a word-processor or a presentation app, but it is crucial for a spreadsheet app.
I REALLY like the intuitive feel of PlanMaker and feel it will work well for most of the things I need to do -- BUT -- without the ability to view spreadsheets side-by-side I will have to use another application. :--(
