csv import problem
thekitehunter
csv import problem
Post by thekitehunter »
I wanted to try Planmaker as an alternative to Libreoffice calc, but it won't import my csv file properly.
The line is:
Fixed Assets,,
11110 - Shop Fittings - Cost,"4,325.60",
etc...
which LibreOffice and Excel both import as two columns:
4,325.60
Planmaker ignores the double quotes (which keep the number together) and instead imports 3 columns:
"4
325.60
making it unusable - is there a way around this?
thanks
pmfrench
Re: csv import problem
Post by pmfrench »
Results in this:
