Edge outline in shadow text in presentation
between3and20
Post by between3and20 »
I've created a presentation and have used the shadow effect for the text so that it will stand out against the background. I've noticed that the shadow is not completely black. Instead, the shadow actually has a orange or yellow outline. Is there a way to make the shadow completely black? The offset orange lines from the main text are very distracting.
Re: Edge outline in shadow text in presentation
Thanks for reporting this problem. Please share the associated file of Presentations 2021 in which you are getting this problem so that we can do further investigation for resolution.
viewtopic.php?f=420&t=22250
Return to “FreeOffice Presentations 2021 for Linux”
