Drawing lines and arrows - getting settings to stick?
pulgoki
Post by pulgoki »
Is it possible when drawing lines, to
1) get it to stick so you're not having to hit <insert> <line> every time, formatting, then moving to the next line?
2) get the settings to stick? As in line ends - arrow, etc.
When marking up a file, I'm having to draw the lines one at a time and add the arrow head to the end every time I draw a new line. It seems to do this with rectangles and ellipses as well?
I'm not sure if this is already possible and I'm missing it?
Re: Drawing lines and arrows - getting settings to stick?
Yes, you can make the desired line and then copy and paste it using Ctrl+C/Ctrl+V, after that you can resize and rotate the pasted line.
Return to “FlexiPDF 2022”
