Set ActiveCell in PlanMaker with script
Larsdddd
Post by Larsdddd »
Hi
I've been playing around with scripts in PlanMaker and they are useful enough. But there's one thing I can't figure out. Is it possible to set the ActiveCell on a spreadsheet in a script?
I've found ActiveCell, which is supposed to be a pointer to the active cell. But is it possible to change the value (the cell adress) of ActiveCell?
Hope for help
Lars
Larsdddd
Re: Set ActiveCell in PlanMaker with script
Post by Larsdddd »
Hi
I figured out how to achieve what I want with SendKeys. But it would still be great to be able to set ActiveCell by supplying a cell address.
Lars
If you want to activate any specific range or cell of the sheet, you can simply use Select method of the object Range or Cell. Please check the below examples:
Code: Select all
pm.Range("B2:F5").select
pm.Rows(2).Cells(5).select
Larsdddd
Post by Larsdddd »
Fantastic!
This is exactly what I need. I should have thought about that. :D
Thank you!
Lars
