Suggestion:
Iron-Duke
Suggestion:
Post by Iron-Duke »
Problems:
1) modal property panels obscure the slide content underneath.
2) property changes are not immediate.
Suggestions:
1) Can you please make the object property panels dockable, to the right, in a simimar way to the way WPS functions. This will enable property changes to be made and affect the object immediately.
2) Within the property pane, change the object property dynamically, or at least have an "Apply Change" button.
Great product! Thanks for considering this change!
Re: Suggestion:
Thanks for your suggestion. I have forwarded this request to our product management...
