Superscript from PlanMaker will loose its character formatting when pasted in TextMaker
Simorgh
Post by Simorgh »
Hi SoftMakers,
If you have a superscript-ed digit in a cell in PlanMaker, that let's say has a position 30% and size of 66%, then copy the whole cell and paste it in TextMaker.
The superscript will become a regular digit, unless you only highlight the digit in that cell you just pasted, then Format > Character > Spacing then untick superscript and then tick it again. Then the formatting will be the same as when copied from PlanMaker, otherwise when you open Spacing right after pasting in TexMaker, it has the position 16% and size 100%.
You can probably replicate this yourself.
Please advice.
Thank you in advance.
Re: Superscript from PlanMaker will loose its character formatting when pasted in TextMaker
Thanks for reporting this problem. I was able to reproduce it and forwarded the details to our developer team.
Simorgh
Post by Simorgh »
SuperTech wrote: Thu Sep 30, 2021 9:08 pm Thanks for reporting this problem. I was able to reproduce it and forwarded the details to our developer team.
Thank you for your reply.
Do you mind checking this thread as well? :
https://forum.softmaker.com/viewtopic.p ... c08fe768b4
Would greatly appreciate it.
Kind regards.
