Zotero - all buttons greyed out
atl068
Post by atl068 »
Hi, I upgraded to Pro just to have Zotero working. Wondering why the buttons are all greyed out? I have rebooted etc. Does it depend on the Zotero version I have installed? I just installed Zotero beta as I am switching from Mendeley so, I need the beta to import it from Mendeley online... Yes, I am switching to Zotero also so that I can use Softmaker Office as my only Office suite on my main carry around laptop.
P.S. I also upgraded from Standard by using the Professional registration code. Is this the problem?
Re: Zotero - all buttons greyed out
1. Install the latest version (5.0.96.3 at this date) of Zotero for windows from here:
https://www.zotero.org/download/
2. Open Zotero, then go to "Tools > Add ons" and make sure that "Zotero LibreOffice integration" is enabled
3. Don't close Zotero and then start TextMaker
4. Go to References > Zotero > Insert Citation. It should work now.
mjavu
Post by mjavu »
I have a similar problem, but the suggested solution has not worked. I am using Softmaker Office 2021 build 1038 (x64) in Xubuntu.
Greyed out Zotero buttons in Textmaker
Please let us know which Zotero version you are using, and did you start Zotero before opening TextMaker?
mjavu
Post by mjavu »
I am using Zotero 5.0.96.3. I am able to use Zotero in LibreOffice. I was also able to use Zotero in Softmaker when I was running the Universal version up to November 11. Zotero has not been working in Textmaker since I switched to the Home version.
Zotero support is only included in the Professional and NX Universal versions.
mjavu
Post by mjavu »
Thanks. Noted.
