Bump the item below about LINKS
enonod
Post by enonod »
Can the following of links not be solved?
It is a fundamental of documents to be able to hyperlink.
Can a loooonnnng press be used, or will this never happen?
What about an icon on the status bar which needs to be touched just before or at the same time as the hyperlink (when it finally appears on the insert menu).
What about a quick drag on the link?
[EDIT] I notice that if a hyperlink is placed in a document using Textmaker Windows and then the document is opened in Android, one can select the link by double click (and extend if more than one word) then use Menu EDIT... 'Go To Link' and it works.
A bit long winded but in those circumstances can we please have the Menu Item INSERT... 'Hyperlink' added to Android version so that it can be used to link to Bookmarks (which is already implemented), otherwise bookmarks are not fully useful.
Re: Bump the item below about LINKS
Thanks for reporting this problem again. I have forwarded the details again to our developer team.
Meanwhile, you can long press on the hyperlinked text, which will open a context menu with option of "Go to link". You can edit the hyperlink from this context menu itself.
To add a new hyperlink, please select the target text, click on ribbon command Insert | Link group | Hyperlink.
Our developer team reworked on this problem and implemented some improvements which will be available in next update of SoftMaker Office 2021 for Android.
