Outline view locks up on selection
enonod
Post by enonod »
IME (rev S1035.0716)
When selecting Outline on the View menu Textmaker locks and has to be restarted. Consistent either with the default document or a loaded document. If another view is selected first then Outline it appears to work OK.
Re: Outline view locks up on selection
Thanks for reporting this problem. Outline view is not opening by default with TextMaker so as you mentioned whenever you will open TextMaker, there will be another view open in TextMaker which you can switch later to Outline view.
Please let us know exactly at what point TextMaker locks up? Please share a screen recording of this problem for better understanding.
